Who can decode Engine Block numbers?
Old Jun 27, 2002 | 07:01 PM
fattie92's Avatar
i never checked to see what my 350 block was out of. can someone run my numbers? they are : 14010207
thanks!
Old Jun 27, 2002 | 10:42 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well its a 350 alright. 1980 to 85 2 or 4 bolt.
Auggie
Old Jun 27, 2002 | 10:53 PM
fattie92's Avatar
its a 4 bolt, a real 4 bolt not the 2 bolt converted to a 4. how can i figure out what cars it was in? im just curious in what it came out of.
Old Jun 28, 2002 | 11:22 AM
fattie92's Avatar
if its a 4 bolt,, dont that mean its usauly out of a truck or a really big car?
Old Jun 28, 2002 | 12:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Usually a truck, almost never a car.
Old Jun 28, 2002 | 08:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That casting number is just the casting of the block. It could have been in many different types of vehicles.
Get the suffix code off the block. It'll be stamped into the pad in front of the passenger side head behind the alternator. That code will tell you exactly what vehicle the block came from.
If the block has ever been decked then the stamped code will be gone.
The stamped numbers are usually hard to see. They're usually full of dirt, grease or paint.
Old Jun 28, 2002 | 08:53 PM
fattie92's Avatar
whats "decked"?
Old Jun 28, 2002 | 11:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
When the top of the block is machined off to make it perfectly flat. It can also be used to make a zero deck height. That's where the top of the piston comes to the very top of the deck. Typically a piston only comes to around .030" from the top.
Old Jun 29, 2002 | 08:44 AM
fattie92's Avatar
ohh,, ok i got ya... well ill look today to try to find that number.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
