View Poll Results: Are poly mounts too much for the street?
Go with GM rubber... they'll hold up and you'll appreciate less vibration for the street.
0%
Go with aftermarket poly... you will be able to put up with the vibrations and they'll hold up to the power
82.35%
Go with some other kind of mount and I will post it below
17.65%
Voters: 17. You may not vote on this poll
POLL: Are poly engine mounts too much for the street? Please post your vibes...
Old Jul 8, 2002 | 02:36 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
85% street driven vehicle making ~500HP. Sees some track time. What is your opinion on putting up with poly motor mounts?
Old Jul 8, 2002 | 04:49 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Moroso Solid Steel Upper and Lower motor mounts and Steel Trans Mount.This car is my daily driver and the difference in vibration is barely noticeable.
Usually people think it's gonna be too much on a street driven vehicle, but I've run the Moroso steel mounts on every chevy I've had since High School.
The shifter doesn't wiggle around as much as it did with a rubber mount. Other than that you probably wouldn't notice a difference.
The nicest thing about them is, they'll last forever. I've never had to replace any of them.
As far as Poly goes, well, I haven't used them, but my torque arm mount and sway bar bushings are poly.
If you're making 500HP, I wouldn't waste my time on anything but steel mounts.
Moroso Lower Mount, Part#62610, $32.99/Pr at Summit
Moroso Upper Mount, Part#62510, $21.99/Pr at Summit
Moroso Trans Mount, Part#62600, $18.95 at Summit
-Rich-
Old Jul 8, 2002 | 10:04 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
I like my Energy Suspension poly mounts.
JMatlock88 - nice hp numbers
Craig
Old Jul 8, 2002 | 11:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
es poly mounts here. no vibes here.
Old Jul 9, 2002 | 12:18 AM
rezinn's Avatar
500-200(N20)=300
Old Jul 9, 2002 | 12:44 AM
Jza's Avatar
Jza
Barely noticable. People just have to whine about something..
Old Jul 9, 2002 | 06:32 AM
JMatlock88's Avatar
Car: 1991 Formula
NO! 500 naturally aspirated horsepower + 150 nitrous.
edit: Real quick... Stealth Ram, Ligenfelter 58mm TB, 4 bolt main 355 ci, forged rotating assembly, arp bolts, SVO 30#, .560" lift retro roller cam, Crane Gold RRs, Ported Pro Action Alum, Manley valves, 10.3:1 cr
Old Jul 10, 2002 | 12:48 AM
Nate2's Avatar
Steel
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
