Engine misses and tach fluctuates
Old Jul 14, 2002 | 04:34 PM
erik_jacobs's Avatar
Lately my car has had a low RPM miss and the tach will fluctuate up and down afew RPM's. This only happens below 3000 or 3500 RPM. Above that, the engine runs great. Just from off idle the car has no power and takes forever to really get movin'.
Anybody have any ideas?? Thanx in advance.
Old Jul 14, 2002 | 04:40 PM
ede's Avatar
ede
any codes? have you tried trouble shooting? is the tune up good?
Old Jul 14, 2002 | 04:47 PM
No codes, did a tune when i pulled it out of winter storage
Old Jul 17, 2002 | 07:45 PM
NOCANDO's Avatar
I had a similar problem. Found out it was my fuel pump going out...it had only 6 psi when I finally checked the pressure. As for the tach, I'd check your pick up coil in your distributor...mine was all rusted out. Hope this helps
Old Jul 17, 2002 | 07:53 PM
WaynesRS's Avatar
If the above answers to this problem does not solve it . Check your vacumn lines .
Old Jul 19, 2002 | 01:28 PM
bhaas's Avatar
I had a miss and it was a broken valve spring. Might check those to.
Brad...
Old Jul 19, 2002 | 02:14 PM
Ride4ME's Avatar
Guages Do Not work!!
I've been trying to figure this one out for some time.
My gas gauge "lies" to me, my temp guage doesn't work at all
and neither does my fuel pressure. This is driving nme crazy. Please help!!
R.
eightsixseven
Dec 16, 2024 01:50 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
