not a thirdgen, but i need some ideas
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
my beater vehicle,
1988 toyota pickup, 4cylinder carbed engine, and a 4 speed manual
the truck will pull fine through 1st, and 2nd, cleanly to 5000rpm (i put a tach in, cuz i had the old one from my car, and no this truck does not have an easy life)
but when i shift to third, it starts stuttering, popping and laying down really bad untill i let all the way out of the gas, and get back in easy, let it pickup speed, then go to fourth and its fine
i'm guessing it has a loose wire somewhere involving the ignition, but its raining right now so i can't go check.
what do you people think?
Transmission: 4L80E/4L80E
Fuel supply. Either clogged fuel filter or weak fuel pump.
Car: 1984 Firebird
Axle/Gears: 4.10
filter is only about 3000 miles old but it did see alot of gravel miles, could be a pump the truck has about 125000 miles on it,
the wierdest part is that it only happens in third gear, and the trannsmission has vo audible whine/grinding, or anything, unless the synchro is getting bad and its trying to double engage gears under load
CarGuyDennis
137
Dec 6, 2016 11:02 PM
