Simple head disassembly question.
Old Aug 8, 2002 | 04:19 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Last night I was disassembling my vortecs to prepare them for machine work. I compressed the springs, removed the keepers, and then pulled off the valve stem seal but the valve will not fall out. When you try to pull them out they just "bottom out" on something inside the guide. Am I missing something here? I've disassembled a few heads in my life-time but none have done this ...the valves just fall out but these will NOT come out at all.
Thanks,
Chris
Old Aug 8, 2002 | 05:40 PM
ede's Avatar
ede
you have a burr on the valve tip or around the keeper groove file it down a little and they should come right out. if you force them they'll remove metal from the guide.
Old Aug 8, 2002 | 05:50 PM
Car: '89 IROC-Z
What would cause all the valves to be like this? There does seem to be a very very slight lip
Thanks,
Chris
Eric2ndGen
Nov 5, 2015 01:51 PM
gta90
Sep 15, 2015 04:00 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
downsouthboy
Aug 29, 2015 11:29 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
