Vacuum lines missing
Old Aug 11, 2002 | 12:39 PM
WildmanDRL's Avatar
Car: 1989 Firebird Formula
Engine: 350 TBI (LO5 K)
Axle/Gears: 7.5 10 bolt peg leg
I recently decided to give a tired 89 Formula a well needed resurection. I have since found out that the last owner had no mechanical ability whatsoever. I've spent the last 2 weeks ironing out all the problems. The question I have involves the vacuum fitting behind the throttle body in the manifold. When I got the car, nothing was hooked up to it. Just an open vacuum leak.
Can anyone tell me what lines run to this fitting and if there are any check valves in those lines. Its not on the vac. diagram under the hood or in the Haynes manual. Any help would be greatly appreciated.
Thanks,
David
Old Aug 11, 2002 | 12:51 PM
ede's Avatar
ede
if it's what i'm thinking it goes to the egr senser.
Old Aug 11, 2002 | 02:51 PM
WildmanDRL's Avatar
I checked it out and the EGR is all hooked up. The only hoses I can find disconected are the cruise control and the heater. I found the heater vac. hose broken off in the harness.
If anyone with a 305 TBI can take a look at their hookup and see if these lines go there and how that would help alot.
This car has been in the hands of several people who didn't have a clue on how to fix it correctly. I would've liked to get one in better shape, but the deal was too good to pass up. The car is all there and straight. The perfect start for a project.
Old Aug 11, 2002 | 09:25 PM
jfox55's Avatar
IT could very well be the heater. I would start with that. If it comes out of the manifold, it should just be like an extra incase needed. (A runner) Mine is plugged, because I didn't need it.
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
