AC help...
Old Aug 19, 2002 | 01:47 AM
JR305's Avatar
AC help...
Ok, back when I installed my heads/cam I put a small hole in my AC condenser and the Freon leaked out. Now I am finally getting around to repair it, as I can no longer take the 110 degree heat here. 5SIZ is going to sell me a condenser out of an 87 IROC and I want to make sure that it will fit in my 92 rs. Also, before replace the condenser, do I have to get the system discharged, or did I already take care of that? Last, should I convert to R-134a with the kit offered?
Old Aug 19, 2002 | 01:58 AM
rezinn's Avatar
If your freon leaked out you really don't need to bother discharging anything. To my best knowledge his condenser will work in your car; the connections are in the same place in both v-belt and serpentine cars, despite the different hose routing and compressor locations. If you convert you'll just save yourself the cost of freon, but r-134a is not as good of a refrigerant so your a/c will not blow as cold. I converted my car just because I couldn't buy freon myself.
Old Aug 19, 2002 | 05:13 PM
JR305's Avatar
Thanks for the reply, does anyone else have any opinions on R-134a?
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
