Need some very experienced help....
Old Aug 19, 2002 | 04:37 PM
khellendros's Avatar
I have a 1988 pontiac firebird 2.8liter. The car keeps runs and will idle fine but when the car is hot and u press the gas it chugs and dies.. the idle will bounce around like mad from 1000 to 450 and just chug until it eventually dies. What can cause this? I changed the MAF sensor... the computer... the EGR valve and solenoid... and the voltages checked out on the TPS sensor through all stages of acceleration.. also changed the IAC valve... (but i'm not quite sure it was put in right). Anything else that any of u more experienced DIY'ers can think of? I need help... this car has been off the road for like 2 weeks now... im losin my mind... HELP!!!!
Old Aug 19, 2002 | 06:37 PM
Anyone?
Old Aug 19, 2002 | 07:01 PM
ede's Avatar
ede
check the cat, make sure the tune up is good, check for codes, run compression test in that order
Old Aug 19, 2002 | 10:33 PM
The cat converter was gutted.... the car was tuned up less then 2 months ago... the check engine light doesn't turn on... no codes... and the compression rates r fine.... I have no clue... anything else anyone can think of?
Old Aug 19, 2002 | 11:18 PM
Ratchet's Avatar
Sorry for stating the obvious but how hot is hot.
If the engine is overheating it will chug, fart, jump the tach all over the place and even quit running.
have you checked the waterpump, and thermostat for proper functioning?
Old Aug 19, 2002 | 11:24 PM
Its not over heating at all... the temp guage is working properly and the temp is well within the operating range. Just still no clue wtf could be happening with it....
Old Aug 19, 2002 | 11:31 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I am having a similar problem except it happens when I let off the gas. Try checking your vacuum lines and see if any came loose. Also your timing chain might need replacing.
antman89iroc
36
Jan 31, 2016 08:42 AM
cheesehomer
Dec 31, 2015 08:48 AM
BrianI
Oct 3, 2015 12:57 PM
mfp189
Sep 27, 2015 09:25 AM
PeteK825
Sep 22, 2015 10:47 AM
