Valve stem seal tester...??
Flipping through the huge service manual i have and this page caught my eye. It shows a 'valve-stem seal tester'. I was wondering if anybody happened to have one or know anything about it? I suspect one of mine might be bad, and think this would give me a definite answer. I have done a compression check and the cylinder in question had a higher reading (about 15 psi IIRC) w/ the plug covered in oil.
The number listed in the catalog is J 23738-A. Could I just go and order this from a dealer or should I look for some place cheaper online??
Here's a picture of the page (sorry i don't have a scanner)...
i've saw that in my manuals too. far as i know what they show would work with o ring seals but i don't know where you'd get the adapter. besides why would you want to, if you have smoke on start up you need seals, thjey're cheap and easy to install.
Car: 4
Engine: 6
Transmission: 5
Really... a $100 tester to test a $5 part, that you have to do most of the labor of changing the part just to use the tester anyway... and all it tests is the drip-down O-ring, which is a futile part at best... not the way I would approach the situation. Looks like something that somebody who spent too much time in classrooms and not enough time on the job would come up with.
355tpipickup
Sep 13, 2015 11:35 PM
