This has probably been beaten to death but "Ripping out an ECM....."
Old Sep 5, 2002 | 12:25 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Lets say I wanted to go with a Carb. Besides the Gauges not working what else is there that you have to worry about? All I can think of is the playing baseball with all the old sensors.
Old Sep 5, 2002 | 12:39 PM
ede's Avatar
ede
if you get a carb and nonecm controlled distributor you won't have any problems and the gauges will work. do a search you'll find lot of info.
Old Sep 5, 2002 | 12:42 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I confirm.
Your signature it outrageous. Looks good on my P4 machine at home, but you bog down my lowly P3-400MHz machine here at work .
Old Sep 5, 2002 | 01:38 PM
Ok I found this
https://www.thirdgen.org/techbb2/sho...omputer+remove
Whats the deal on the converter?
Old Sep 6, 2002 | 03:35 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have an 86 or newer Bird, you will need to isolate the wires for the VSS from the engine harness.
I went to a non-cc carb and just cut the harness off and then my speedo stopped working till I found out what wires were needed.
Old Sep 6, 2002 | 03:45 PM
Odyssey's Avatar
Just leave the damn ECM ALONE and you'll be fine. I dont why people are so eager to "rip out the ECM". Leave it in there and let it run your fuel pump, speedo, etc... It's not gonna come out and bite you while you're driving. I swear !
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
cstrobel65
Sep 16, 2015 11:54 AM
greenyone
Sep 8, 2015 08:41 PM
