Do I need new gaskets? when I do a head install?
Old Sep 18, 2002 | 01:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I know I'll need new head gaskets. But I just did a cam swap, and I will only have about 400 miles on the motor at most hopefully when I do the head install.
Can I reuse the intake gasket (fel pro) and valve cover gaskets (fel pro)?
Old Sep 18, 2002 | 01:35 PM
ede's Avatar
ede
valve covers yes everything else no, even if it looks good trash them and buy new
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i would definitely recommend new head gasket even if u didnt change heads and took em off. cheap insurance my friend
Old Sep 18, 2002 | 01:39 PM
Car: 99 Formula
Axle/Gears: 342
I planned on new head gaskets, I wasn't sure about the intake gasket mainly.
Old Sep 18, 2002 | 02:42 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
sorry i just re-read that i think ede actually does not use a gasket on his manifolds i want to say he said that he make his own silicon gasket. dont quote me on that but i would pm him and ask.
Old Sep 18, 2002 | 02:45 PM
rezinn's Avatar
Replace intake and exhaust gaskets, reuse the valve cover ones unless they are torn or burned.
Old Sep 18, 2002 | 06:40 PM
ede's Avatar
ede
i use ultracopper on the china walls if the engine is still in the car, if it's out i use the china wall gaskets. with the engine o na stand i can see and handle the intake a lot eaier and not mess up. no idea why i don't just use silicone for them reguardless, but that's how i do it, plus use the long gaskets either way.
Old Sep 18, 2002 | 07:14 PM
LarsZ28's Avatar
My engine guy ordered center bolt valve cover gaskets for my car, but I dont have center bolt heads, can I still use these? (they are the blue rubber type Fel-pro ones)
Old Sep 18, 2002 | 08:39 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Even with those little of miles on them I doubt you'd get the intake gasket off cleanly anyways. Might as well just spend the bucks ahead of time.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
