Ignition module Question
Old Sep 18, 2002 | 01:41 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
My engine refuses to rev past 5000 rpm. I have all the choice parts in it but the only thing left "factory" is the ignition module.
Do I need an aftermarket module to get past 5000 rpm or is the factory Delco unit fine?
Old Sep 18, 2002 | 02:08 PM
flyway190's Avatar
I doubt it's really causing your problem, but the factory ignition control module sounds like crap at higher RPM's and I would suggest replacing it anyways. You can get an Accel module for about $50, it's a direct replacement and smooths the top end out a lot. To answer your question though, my engine revs past 5000 no problem with either module.
Old Sep 18, 2002 | 04:03 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Replace the module but not with an aftermarket unit. Thier too damn much money. Get one from the dealer or any autoparts shack. Almost all of these modules are made by the same company anyways.
But like it was stated earlier, it's probably not your module.
Good luck.
Old Sep 18, 2002 | 04:58 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Something to think about, if your timing is off the motor won't rev very high, this is a tried and true fact cause when they have the midnight races all the 10-12 second cars back their timing waay down so they can hook, cause they don't treat the track with all the ricers and other street cars-the event is really for them anyway, but we still take their money, anyway back to point, they usually back it down from 40-20 and the motor has a hard time reaching a half way "normal" shift points.
BRoss99
Aug 10, 2025 05:08 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
