compression and fuel
Old Sep 18, 2002 | 01:57 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
If I run 11.1 compression can I get away with running 92 octane?
Old Sep 18, 2002 | 02:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: compression and fuel
Nope, I believe 10:1 is max with pump gas , though I hear you can get away with a little more nowadays, not sure how true that is.
Old Sep 19, 2002 | 12:44 AM
Engine: 350 L98
I ask a guy I know and he said you can only if your running aluminum heads.
Thanks Mark
Old Sep 19, 2002 | 01:50 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
10 : 1 is the most you can use 92 octane fuel for.
Old Sep 19, 2002 | 02:10 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Around 10:1 +/- a smuggin' is about the limit with cast iron heads. Alumium heads can go about .5 more.
A true 11:1 is pushing it.
There are some variables that will affect the ultamite limit.
And every motor will be a little different.
I'd build for 10.5:1 for alumium heads on 92 octane.
The trouble is,,, having just a little more compression than
*your motor in your car* needs will result in spark knock
which kills power and can damage your motor.
Being slightly under the absolute limit, is not going to hold you back any and you'll go a lot further for longer
Old Sep 20, 2002 | 01:23 AM
Engine: 350 L98
Thanks for the input man.
Does anyone know of any race fuel dealers in Canada?
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
