What the hell is wrong?!!
Old Sep 21, 2002 | 08:36 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
My car seems to be getting only around 10mpg. With the old 305TPI (LB9) it was getting 18mpg and 25mpg on the freeway. The only thing i have done is put in a 350 TPI (has old 305 TPI set up on it) with 21lb fuel injectors, and a mild cam. The guy who put in my engine says that it has around 275hp at the wheels. There shouldn't be that much of a difference in mileage should there? Will this pass as time goes on? I do know that the cat and muffler are bad and am getting those fixed next week. What should i do? Any help would be great! Thanks!
Old Sep 21, 2002 | 08:46 PM
rezinn's Avatar
Something has got to be wrong. What kind of chip are you using?
Old Sep 21, 2002 | 08:50 PM
What do u mean? I didn't get a different chip.
Old Sep 21, 2002 | 11:28 PM
laiky's Avatar
do the cat and muffler first then worry about it
Old Sep 23, 2002 | 09:19 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
you should be using a 350 chip, not a 305 one
Old Sep 23, 2002 | 09:20 AM
Car: '87 Camaro LT
Engine: 355 L98
oh also, what knock sensor are you using? a 305 one is more sensitive than 350 so your ecm might be over retarding your timing due to false knock
Old Sep 23, 2002 | 04:25 PM
Ukraine Train:
Where can i get a 350 chip, what kind do i need (brand/name) and how much would it cost? Thanks!
Old Sep 23, 2002 | 05:36 PM
Car: '87 Camaro LT
Engine: 355 L98
since your car is an '86 i'm assuming it has a mass air setup (MAF sensor). the easiest way to get one is find a used ECM with a chip already in it that came from a 350 with Mass Air tpi, not speed density tpi. the Speed Density tpi computer number ends with 7730, that's not the one you want, do a search for 'MAF tpi computer number', i dont know the number off hand. there's always some floating around ebay for $50-60. speed density was used 90-92 i believe.
Old Sep 23, 2002 | 06:02 PM
ok thanks ill check it out!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
aaron7
Sep 30, 2015 09:15 AM
