Stupid question inside.
What is this thing that I have circled? What is it's function and can it be removed? The other thing is the heater control valve I think.
Bill
(this is not my engine bay)
Bill
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I believe that's called the air diverter valve. It's for emissions. I removed mine.
The other one is a heater valve. I haven't found a way to remove that yet and still keep my hot/cold choices.
Oh the days. I had forgotten how a lo3 was supposed to look. Yes you can remove that. There is electrical connection going into it but you wont throw any codes. When you take that out go ahead andremove the smog pump also. You still have all kinds of stuff you can remove
You can remove the heater valve by setting the car up like older cars. You can run a line directly from your waterpump to the heater core then a line from the heater core back into the intake. You will still have one line running over that way but it would be much more convienient.
Thanks for the reply's
Bill
Iroc8t8
May 4, 2026 08:09 PM
