Project Stealthram / AFR195 355 project finally almost finished...
#52
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Originally posted by JMatlock88
Yes, apologies --they are just computer generated numbers. Not from desktop dyno software, but a $3K package that is supposedly much more accurate. How accurate, we'll find out Oct 21st. If anyone wants to come watch, I'll be in tulsa at Fastchip!
#54
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Now THAT'S what I'm talkin 'bout It just shows what puting together a plan based on good research of component compatability will do for you. While the cheaper desktop dynos may be a little off on the final numbers they will still point most members in the right direction. I'd recommend them to anyone considering their low cost.
#55
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Here are 6 video clips of the dyno footage. I split it up so it would be more modem friendly. I hope you like 'em!
:lala:
On the recent guestions about exhaust and my combo, I'll get back with you soon. It's been a busy week! Later!
video1 video 2 video 3 video 4 video 5 video 6
Thanks to bort for letting me use his server!
:lala:
#56
Car: '99 HO Z28 / '03 Trailblazer
:lala:
:lala:
#58
Car: 1991 Formula
You need to download the divx codec at www.divx.com. It is very simple to do.
I plan on taking it to the strip when I get a hood and some wheels (draglites or comprable). Yes, it will probably be tulsa or noble. If you know of anyone in the area who has a cowl hood for sale or wants to trade a set of ROH ZS 16s for some fat/skinnies, let me know.
The software is called Performance Trends
The basic mods are:
1969 350 4 bolt main .030 over
all name brand bearings, etc
all arp fasteners
forged crank and trw forged pistons
polished aftermarket ibeam rods
afr 195 68cc street CNC port
224 224 560 560 retro hydro roller custom grind cam
1.6 Crane race gold rockers
hardened pushrods
moroso pan
sfi 8" balancer
sfi flywheel
ministarter
stealth ram
58mm BBK
afpr
SVO 30s
msd pro billet distrib
crane hi-6s
accel supercoil
alum waterpump
alum 3 piece udrive pullies
hooker supercomp 1.75" longtubes
dual exh w/ 2 40 series flows
stage II 700r4 w/ torco 3100 lockup stall w/ antibalooning
150 NX shark nozzle w/ 10lb compucar bottle and solenoids
completely full interior w/ a/c and all options except ttops, rear defrost, foglamps.
brakes are stock
wheels are Ronal Firehawk 17s
aluminum 1le driveshaft
10bolt w/ 28 spline moser axles, 3.73s, cclip elim, alum stud girdle
spohn control arm lowering brackets
hotchkis control arms
ssm sfc's
...that's a general look at the driveline
I tried snapping some pictures of the exhaust, but I'm gonna need to put it up on jackstands to take pictures.
The basic mods are:
all arp fasteners
hardened pushrods
moroso pan
sfi 8" balancer
sfi flywheel
ministarter
stealth ram
58mm BBK
afpr
SVO 30s
crane hi-6s
accel supercoil
alum waterpump
brakes are stock
ssm sfc's
#60
I have the 236/242 cam and a Mini Ram on my 383 right now. It makes decent power. I havn't tuned the car and I run mid 116 in the quater on street tires, getting in and out of the throttle. I can't really hit it till third. I got a clean pass the other day and ran 126 on the G-Tech. I am running the AFR 210's with a bowl blend. They flow 300cfm@.600int and 261cfm@.600exh. I just orderd a single pattern 242/242 .576/.576 because of the 89% int. exh. ratio. I think I am putting down around 415-420 at the tires. It pulls to the rev limiter at 6,700 with no rev kit. You should be able to run 11.40@116 with 380 at the tires. I am also running Hooker LT's with dual 3" and an X pipe, and a little more compression than you guys, 11.2:1. The car weighs 3640 with me in it.
#61
Lethal - 261.6 cfm @.6” is remarkable for a 23 degree std exhaust port head with 58cc combustion chambers and “a bowl blend”. In comparison, Weldtech’s fully CNCed ported “Hutter” 18-degree “NASCAR style” heads with 1.625” valves are “only” flowing 256@ .6 and 261 @ .7”. I’d like to know what size valve is being used and who did the work. If you’re sure his bench was not off,, and even though I’m sure more had to be done than just a bowl blend,,, I’d like to talk to the guy.
#62
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
His intake numbers are in the link below, under ported AFR 210, I don't have his exhaust numbers.
I wouldn't exactly call an AFR 210 CNC comp porting, plus hand porting, a 'bowl blend'. http://briefcase.yahoo.com/bc/micdoc...+tests&.view=l
#63
BadSS. I know the exhaust seems out of wack but it is the truth. Brian Tooley at Total Engine Air Flow did the bowl blend. The heads have a 1.60 exh valve. They were flowed at 28" of water with a 1 7/8 round flow tube. With a square to round flow tube they flowed even more. All he did to them was smooth the CNC out of the port and the bowl. The only thing done to the bowl extra was blend it into the valve. Hence the "bowl blend". I went rounds with a nother guy about a year ago and posted my charts and the argument was over. 89gta383 posted my intake numbers. I guess he doesn't have the exhaust. Shoot me and E-mail and I can fax or scan both charts and graghs and send them to you. I don't know how to post them on this sight. I think Brian put my heads on the CNC computer of his to get the profile. He was as shocked as any one else. You can see from the charts that they were flowed on a Flow Pro bench with computer read out on different days. The flow was done with a 4.030 bore which hurt intake flow because of the small chamber and the 2.08 int. valve. Research " insane flow numbers " I can't remember if it is on this site or on www.camaroZ28.com.
#64
I'd like to point out a few things to those who are rightly impressed by this thread and it's author's accomplishment:
1. Notice how every shot is operating room clean? Yeah. That's how it SHOULD be. That's the environment you should build engines in for a million different reasons. Frankly, I'm embarassed beacause my shop (detatched garage with a bare 100W light bulb) doesn't even come close.
2. RESEARCH WAS DONE PRIOR TO PARTS CHOICE WITH AN EYE ON THE TOTAL COMBINATION OF PARTS. He ran dyno simulators. He read the specs on the heads. Who here would have recommended a cam as small as what he used? Who would have recommended a single pattern cam, for that matter? Probably very few. Total combination is VERY important.
3. He tuned the snot out of it. From 308 RWHP from "best guess" first chip program to 380 final best program. 70 HP In 10 itterations of programming! How much time have you spent tuning your combo? Have you spent this much? A fuel injected combo will always require more attention to detail by it's nature, but don't think you can slap on a carb and bypass all this tuning effort- they ALL require tuning. I personally think most people leave about 30HP on the table by not spending the time to dial it in exactly. And that's almost FREE HP, except for your time and effort.
Congrats and let's hear about those dragstrip times!
#65
And what Damon said - Excellent job Matlock!
#66
Car: 1991 Formula
Thanks for all of the nice comments you guys have made about the selection of the parts and the care I took with the project. I am a proponent of being clean because it really saves time and money in the end. I've been reading these boards since early 1999, and I owe almost all of the knowledge and research to these board archives and TGO friends.
For those of you who were wondering, this is almost exactly what my exhaust looks like. This is the picture I took to the muffler shop to explain what I wanted. It hangs very low, but I can live with it. The exhaust is the same except I have a stainless LT1 style tip (exits parallel to the pinch weld) insead of the round tip shown. I plan on changing to dr gas oval someday when I have an extra $800 lying around.
#67
Sorry BadSS. I just get a little defensive because of all the grief I have taken in the past on the flow numbers. TEA and Brian Tooley are great. I would definatly give them my next set of heads.
JMatlock88. I ran my exhaust like that to begin with also. I was giving up about 20hp and a lot of smoothness. I went with an X-pipe and put the mufflers under the rear seats before the axle. It sits up higher in the critical areas and sounds a heck of a lot better. It only cost me $100 at the local exhaust shop. Just a suggestion. I think you would like it alot better.
#68
Car: 1991 Formula
Lethal, do you have any pictures of your setup? I'm not sure how you fit them underneith the rear seats. I am also concerned with fumes. I've had exhaust rigged up in the past where it completely drove me out of the car when the windows were up. What mufflers & xpipe did you use? Why do you think your setup is 20HP better?
#69
TEA!!!!
tea in bowling green is ****ing awsome people!!!!!
they will do the best that money can buy....... i had a misunderstanding with their billing girl on a price qoute they gave me to my door, and they fixed it no problem....
awsome people, great price.... you just can't beat them......
#70
If you run individual pipes there is no balance. You need to equalize pressure. The X-pipe creates vacuum also. This helps scavaging. I used Flowtech Afterberner mufflers. The exhaust shop fabbed up the X-pipe out of the dual 3" system I ended up running. I get no fumes in the car. I think it runs great. I don't have any pictures of sound bites. That sound bite that was posted with open headers. It sounds pretty much like that.
#71
Car: 1991 Formula
Sounds like that's a neat exhaust setup you got there. Does it exit at the rear axle as in this picture or at the rear wheels like the blue camaro picture? Thanks!
#72
It looks just about the same as that exhaust in the picture above. I have larger square mufflers a little further back that dump right at the axle. That system looks much cleaner than mine. Mine was fabbed at a local exhaust shop. I need a real Dr. Gas X-pipe to maximize the flow. The guy that did my exhaust did his friends Mustang and they said they picked up two tenths. That is about twenty hp. The Mustang guy is the one who talked me into that style.
#73
Car: 1991 Formula
Sounds good. There's definetly some power left in exhaust for me, but for now the cost doesnt justify the change. I'm not changing exhaust until I can afford the oval Xpipe setup. It is good to hear that you dont get fumes with the dumps. That surprises me.
A new question...
Why do you all think my factory tach is off? Will the new MSD pro-billet distributor make the tach more precise or does that not have anything to do with it?
A new question...
#74
I am not sure. I believe that my tach is off also. The shift light comes on at 6,200 but the tach says 6,400-6,500. I just use the light. I wonder if it is right and the rpms are just rising too fast to notice the accuracy.
#75
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Looks good. Great numbers. Looks like a whole lot of torque down low. Drops off pretty quick though. Am I reading the chart right?
I guess I got to break down and get my car dyno tuned. If I don't, I'll never be driving this car. I have no time to gather O2 readings.
#76
One thing is eating away at me about JMat's combo. If you look at the dyno graph, the torque peak appears to actually be below 3000 rpm's. That blows my mind. Does that mean that a stall converter below 3000 would yield maximum ET?
Help me out here. I thought for sure it would peak torque would be around 4000 in that motor.
#77
Car: 1991 Formula
The torque converter stalls until 3100 RPM. Anything below that on the graph is not accurate because of the torque converter slamming into the driveline and therefore multiplying torque. Am I correct on this?
edit: What I dont understand is why my torque reading plumits across the graph instead of remaining reasonably flat. Can someone comment on this?
#78
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Originally posted by GofasterFirebird
Also, most graphs I see have torque curves that are flat at some point. This is not the case with this engine. Comments? I know the charts for tq and HP are different and the tq ones favors a negative slope but still.
The curve looks different (more slope) because
the scaling is different..
Matlock, what gear did you dyno in?
Did you have the TCC hard locked?
What did you do about the TV cable?
I'm curious that your curves start at ~2800rpms, but you have a 3100stall converter?
Finally, would you mind reposting the dyno curve with the SAE conversion factor?
(STD isn't used much to compare to others..)
FWIW, my 700r4 with 2800 stall won't dyno below 3400-3600,
or the trans will kick down to 2nd gear..
thanks
mike
#79
Car: 1991 Formula
The TCC locked up at 95MPH. The dyno pulls were 1st through 3rd gear. The tv cable was hooked up normally. Yes, actually I ordered the stall converter to stall at 3500 rpms but Ed Wright said it was actually stalling to ~3100. I'm definetly no expert on commenting on these dyno curves as this is my first experience. I think I have the SAE graph. Let me find it and I'll post it very soon.
#80
Hell if that dyno graph is accurate then you lucked out by the 3100 stall instead of the 3500 The reason I'm so interested in this is because I want to order the absolute perfect converter for my setup from Yank.
JMatlock-You got me really fired up because I've got the 224/230 cam that Ed said would make max. power in that 355. Same intake, same heads.
Can't wait to see your track times !!!
#81
The TCC locked up at 95MPH. The dyno pulls were 1st through 3rd gear. I think I have the SAE graph. Let me find it and I'll post it very soon.
and stab the throttle. 700r4s are difficult because you have to leave the TV cable
on for line pressure, but you have to be going fast enough not to downshift..
I have my Mandatory TCC lock set for 120 mph
so it won't affect my tests on the dyno or the
track.. 8-)
The SAE numbers will be interesting, thanks..
For reference, my HSR dyno is here:
http://www.eecis.udel.edu/~davis/z28...age021105.html
I stabbed a personal best time at the track the following day with a 11.8 @ 114 (NA)
Can't wait to hear how fast you take that sucker down the track!!
thanks
mike
#82
Shouldn't cost that much for the simple crossover pipe. Spray some cheap paint (not high heat) paint on the pipes and see where your hot spots are in the pipes and connect them or get as close to connecting them that you can. That's usually worth around .12 seconds on a low 12 high 11 second automatic at the track over straight duals.
#84
Originally posted by GTAracer
How come your dyno curves for HP/Torque do not cross at 5250 rpm?
It's already been pointed out that the
HP and TQ scales are different, so they
still cross at 5250rpm, but that's not
the same xover point on the dissimilar
scales..
mike
#85
Car: 1991 Formula
I wanted to add an update...
I have now gotten the Stealth Ram to fit under the formula hood (with some braces neatly removed). All 6 faces of the stealth ram plenum were milled, the most materal being taken from the top and bottom for clearance increases. Enough material was left so that the box was structurely sound for torqing down to the lower. The machine work included milling off all of the ugly (in my opinion) fins. The runners on the base were also milled just 1/16" for more clearance. This change in length should hardly be noticible to the chip and to you. The end result is a fully polished plenum with a shorter and wider look. Thus eliminating the kleenex box syndrome and fitting it all under the hood.
#86
Damn you make me jealous every time I see your engine because yours is actually RUNNING . Mine still looks like this:
except the lower intake is on now. I had a bit of a fight with the dipstick this past weekend as I learned that the Callies splayed caps and the stock dipstick don't get along as seen here:
My oil pan was already on the engine and the engine was already in the car when I learned this, so Nick @ Nu-tek sent me this picture to illustrate what my problem was. I've got a work around though (again, thanks to Nick @ Nu-tek) and I'm back on track. Hopefully I'll be able to fire my beast up before Christmas. A man can hope anyway
#87
damn brad!!!!
can i have your valve covers????? please....
i tried to get some of the proform/gm ones but my dealer couldn't get them yet so i had to go with stock new ones.....
how much clearence do ya have on your 396??? rod to block wise?? i bet you had to grind like hell for 396 cubes........
#88
Car: 1991 Formula
Ya, cool valve covers!
You can see a ton of block clearancing in that bottom end that he posted.
#89
Car: Damn
Engine: This
Transmission: New Stuff
Brad,
Which valve covers are those? Those are the tallese centerbolts I've seen! where did you get them?
thanx
thanx
#90
The valve covers are cheapy polished aluminum that I got off of ebay. They look good though, and are well worth the price (around $90). Search on ebay for "centerbolt valvecovers."
Here's an updated picture that I got off of my camera tonight. Slow progress for sure.
#91
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You will have alternator clearance issues with valvecovers that tall if running a single serpentine belt.
#93
JMatlock. Were you the one saying you dynoed with the stock distributor but had a MSD pro billet ready to go in? If so, have done the swap? Do you notice any difference?
#94
1 Post
Car: projects.......
The stock tachs just don't seem to know what to do w/ themselves sometimes. With my new 355 in, when I kick it, my tach will wiz up to like 2800, then fall back to 0. All while the motor is still winding up. I ordered a new 5" Sport-Comp Silver to eliminate this problem... - I'm soon to order in my new Stealthram. I just can't decide whether to wait and get my Ram-Air hood first, or mill the intake. - I have to do something. This 11mpg carb thing is killing me! I'm getting 19 highway, which ain't bad, but 9-11 in town sucks!
#95
Car: 1991 Formula
Yes, I did swap distributors back in the first of November. I really can't tell a difference, but I'm psudo certain there is a small difference at high rpm. The butt dyno isnt accurate enuf to know...
I got a new digital camera for christmas, so it's really nice to have one that actually produces good pictures more than once every 100 shots.
Yes, the tach has no idea what's going on above 4500rpm so it seems.
I'd like to give a quick update on the car. I recently received a shiftlight and tokico struts. I've also been hard at work on some white face guages. They turned out very nice.
The passenger side strut went in today. It takes no time to swap them out as long as you have an impact gun. Otherwise, it will leave you scratching your head.
#96
Car: 1991 Formula
Here is a better look at the clearanced HSR. Sorry for the poor picture earlier...this one much better describes the new no-so-kleenex look.
#97
Car: 1991 Formula
And lastly here are the new white guages. Notice the 180mph speedo, the new redline, the Formula writing in Firehawk font, and various other tweaks. I started with a few of the freely distributed templates on the internet and modified them to my taste. If you like the templates, just email me and I can send you the real files (much higher resolution). I used red 194 bulbs and made the guage backs out of clear plexiglass. The stock guage faces showed through at night so I had to fab the plexiglass. They really look sharp at night now.
#98
Car: 1991 Formula
the other two
tach and speedo..
#99
1 Post
I say again, you have one hell of a beautiful car and engine. Nice job on the gauges. I did the plexi glass thing w/ mine too. Well, actually I use lexan, but thats what I had...same difference. I also modified mine. I erased the kilometers on the speedo and put in the GTA side logo. I also did some "editing". My tach now says "Give-a-Sh** Meter" rather than RPM x 1000 - What did you think of the Tokicos? I'm running the KYB's right now because they were free. The struts are deffinitely easy w/ an impact. I had to use a 3/4 drive, man those things held on for life. - anyhow, good luck
later, justin...
later, justin...
#100
Car: 1991 Formula
Glad you found the guage templates to be of good use! Thanks for the compliments! I have put about 5 miles on the tokico struts, so I dont really have a good feel of how well they work. I trust the opinions of many board members in that they're basicly the best strut for our application. I hope you have great luck with your KYB's!
Hotrodboba400
12-10-2019 07:07 PM
