How much HP does a lo5 have?
My 305 is toast and im looking into getting a goodwrench 350...anyways what do the 92-93 caprice fleetwood engines have HP wise? www.ftforce.com says 170hp and 255lbs...no way...
Car: 99 Formula
Axle/Gears: 342
The GM Goodwrench comes with 249 hp @ 5200 rpms and 304ft/tq at like 3500 rpms.
This is not the L05 motor though, they're a little different. i believe the code is L51 or soemthing like that.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
250 HP Ha! i really think those values from gm are way too optomistic for that engine. The head castings are kinda crappy and the stock cam is pretty weak. It looks like im getting around 220 HP out of my gmbadwrench 350. Ive spun it up to and past 5000 rpms, there aint much out there. And its not because of the throttle body i have the pressure drop is <10% in the manifold. Other than the lack of high end power, the engine is pretty decent for what it is. Gets good gas milage to boot.
Car: 99 Formula
Axle/Gears: 342
That rating is with open headers and cast iron intake.
The cam in it doesn't produce much power past 3500 rpms.
I dunno exactly how much power and torque it has, but I should be running in the high 15's with my setup and little traction.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Originally posted by TBI305Camaro
Get this.........motor is fine im retarded. A valve spring broke and I didn't notice it till i was pulling the timing chain cover
Oh well Im swapping cams now.
