what is this on my engine?
Old Jan 5, 2003 | 11:51 AM
cfirebird86's Avatar
Car: 86 firebird
Engine: v6
Transmission: 7004r
..what is this thing i am holding?
Old Jan 5, 2003 | 12:03 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
all i can say is i don't think my car had that thing....mine must be a little girl car...
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
ggod question can you trace it through the bulkhead/fire wall it seems to run inside the vehicle.
do you have cruise control?
can you tell if it had fluid in it or is it a vaccume type hose/line?
i personally do not have much experience with the 2.8 but i will try to find out what that is for you
PonchoTA's Avatar
It's a cable protector for some cable going inside/outside the car, thru the firewall. For, like throttle cable, speedo cable, like that.
hth
Old Jan 5, 2003 | 12:09 PM
Car: 86 firebird
Engine: v6
Transmission: 7004r
thanks. I will check it out And yes i have cruise control.
Old Jan 5, 2003 | 02:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is the remains of the speedometer cable. It should screw into the cruise control regulator, when it has had its center reinstalled.
Old Jan 5, 2003 | 04:05 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
:sillylol: i think its the cruise control cable if i remember correctly.. i yanked mine out
Old Jan 5, 2003 | 04:43 PM
Car: 86 firebird
Engine: v6
Transmission: 7004r
my cruise control works okay so is it something extra for it or what.
Old Jan 5, 2003 | 04:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It goes from the cruise to the speedo. The trans gear drives the first cable, which drives the cruise; then that cable goes from there to the speedo.
Old Jan 6, 2003 | 08:07 AM
felo72's Avatar
Is it a vacuume hose with a black plastic end? There should be another black plastic end that it conects to, but I'm not sure what it's for.
Old Jan 6, 2003 | 08:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is the speedometer cable.
What happened to the center? Without the center, the speedo won't work.
Old Jan 6, 2003 | 07:23 PM
Xceleratemaro's Avatar
it could be for the windshield wiper fluid squirters.
Old Mar 5, 2003 | 12:47 PM
Car: 86 firebird
Engine: v6
Transmission: 7004r
what is it
Maybe something is missing. that would be why my speed seems to be off 10 mph
Old Mar 6, 2003 | 02:58 AM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
are you sure its not the lady in the pic?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
