I need to know the specs of the zz3 cam. (Dyno 2000 users)
Old Jan 6, 2003 | 08:47 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Here is what I put into Dyno 2000.
406 cid
afr 190's 2.05 1.60
10.5:1
single plane
small tube headers open exhaust
750 cfm carb
zz3 cam
My results are almost too good to be true. I get 540 hp at 6000 rpm and 537 ft. lbs. at 4500 rpm.
Do I have the right cam specs?
roller
seat to seat
.474
.510
IVO 23
IVC 72
EVO 73
EVC 27
Old Jan 6, 2003 | 09:24 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Use the seat to seat,adv. duration and hydraulic flat-tappet.The roller selection is for race only cams and give way to high numbers.
Old Jan 6, 2003 | 09:27 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
That gives me 480 hp at 5500. Is that more accurate?
Old Jan 7, 2003 | 04:37 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I got 453hp at 5500rpm. I like to use the head flow #s from here http://www.chevyhiperformance.com/techarticles/41598/ all the heads are flowed on the same bench.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
