what makes l98 so special?
Old Jan 8, 2003 | 03:21 PM
kshaw88's Avatar
im trying to find out whats the difference between the l98 and the regular 5.7? is there a difference?
i want a forged internal setup, should i take an old l98 block and add the pieces myself or just buy a zz block?
a little bit of what im doing...
forged block
HSR intake
afr 190 heads
lt4 hot cam
Old Jan 8, 2003 | 03:22 PM
Marshall89ws6's Avatar
get a bigger cam than the lt4 hot cam
Old Jan 8, 2003 | 03:25 PM
kshaw88's Avatar
this is also going to be pretty much my daily driver, i want SEMI decent gas mileage. what do you recommend? i looked at scat and comp cams but i dont know how to decipher the specs.
Old Jan 8, 2003 | 03:43 PM
id reccomend one of these :
comp XE264HR
Grind: 264
Lift: .487''/.495''
RPM Range: 1200-5200
comp XE270HR
Grind: 270
Lift: .495''/.502''
RPM Range: 1600-5400
with the amount the AFR 190cc heads flow.... you should take advantage of the airflow with larger cam than the lt4 hot.... those cams would be good.... the 264 is probably what u want... for a little more power and lift you could slap on a set of 1.6 rockers.
Old Jan 8, 2003 | 03:58 PM
iroc22's Avatar
There's nothing special about the L98 shortblock. Get yourself any 350 core and build it the way you want to build it. I'd recommend getting a 85-up block so that you can use the same flywheel though.
lt500r55
Sep 1, 2021 01:30 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
mizz0313
Aug 12, 2015 06:45 AM
