free goodies
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
free goodies
a guy my friend works with wrecked his monte, threw all the hot rod parts off of it into his garage, and has finally decided to clean this garage out
guess who just got about $700 worth of free parts
here's what i got:
holley 4160 600 cfm carb
water pump
nearly brand new oil pump
box of nuts, bolts, lifters, etc
and best of all...................1.6 ratio comp cams roller tip rockers
i think i am going to use these rockers on my 350 i am building......for these (because they are 1.6 ratio) what do i need to do to my heads?
i saw the comp cams louis tool that you can use to cut the pushrod slots emlinating the need for guideplates
is that all i will need? or is there more i have to do?
here's what i got:
water pump
I could be mistaken, but I thought the "Louis" tool (drill bushing. to the rest of us) was used to elongate the push rod holes in heads with non-self aligning rockers (older style heads) for clearance. You cannot make a head designed for self aligning rockers into one that uses non-self aligning rockers without guide plates.
Originally posted by 1991tealRSt-topGuy
ummm i'm using 416 heads, i don't think they are self aligning...............???
Free tools and parts come with a price that's hard to beat.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
FueledSoul
Sep 26, 2015 12:00 PM
