WOT problem
Old Jan 24, 2003 | 09:45 PM
cdogc350's Avatar
WOT problem
383...large cam, 292/297 i believe...edelbrock perf. rpm intake..750 edlelbrock carb mechanical sec.
Heres the problem.......
When i give is WOT, the car doesnt burst with takeoff, but when i start letting off the throttle slightly it start to take off faster. it seems to pull faster a little after half throttle, then it does at WOT.
Would this be that i need bigger jets, pretty sure the jets are from outa the box.
Maybe something to do with that "air valve" thing on the secondaries which im not too familiar with its function?
Old Jan 24, 2003 | 10:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Step 1:
Lose the Edelbrock (Carter). Replace it with an actual performance carb, either a Holley or a Demon.
Your secondaries are lean.
Old Jan 24, 2003 | 10:37 PM
cdogc350's Avatar
When i open my third gen mail and i see "RB83L69 has just replied to your post", a warm smile comes upon my face, cause i know my problem is usually solved.......
was as i expected the problem to be.....
..once again sir...i thank you for your time.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
