somethings wrong Red exaust
Old Feb 7, 2003 | 06:57 AM
kptkid's Avatar
I just swaped from a 2.8 to a 3.4 in a 86 camaro and the engine runs fine but its getting reall hot and the exaust manafold turns red.?????? anyideas?
Old Feb 7, 2003 | 07:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hugeky retarded timing.... check the dist placement obviously, make sure the ESC connector that you unplug to set the timing is hooked up
Old Feb 7, 2003 | 07:22 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Like he said, very retarded timing or your car is running VERY lean.
Old Feb 7, 2003 | 11:38 AM
kptkid's Avatar
problem... the engine orginally had electroninc ignigtion on it with sensors to set the timing. well I put a distributer on and there is no mark on the block to use a timing light. How could I set the timing???
evilstuie
Jan 9, 2020 08:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
backtothe80s
Sep 5, 2015 12:39 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
theurge
Aug 21, 2015 12:46 PM
