Simple Crank Pulley Question
Old Feb 25, 2003 | 12:02 PM
usa1racing's Avatar
Will the crank pulleys from older (pre-86) motors bolt up to the balancer on the new motors, namely an 88 305?
Old Feb 25, 2003 | 12:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes
Old Feb 25, 2003 | 01:16 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
to add to this, i was putting my dampener on last night and the bolt is to big for the crank. this bolt was on my 72 350 before. is there two sizes for a crank bolt or something?
Old Feb 25, 2003 | 02:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. They are all 7/16"-20 (fine) when they leave the factory, except for certain steel-crank 283s before about 65 which had no bolt at all. Unless of course, somebody has re-tapped it or something, which is probably what had happened to your 72 model motor.
Old Feb 25, 2003 | 03:37 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
well the thing is is that the old crank and bolt were off the 72. i went to put the bolt on my new 383 and it was to big and wouldnt even start at all, hence why i say to big.
Old Feb 25, 2003 | 03:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like somebody sodomized the 72 motor (probably tried to turn the motor by hand with the bolt), and drilled the hole out, and stuck some wrong bolt in it.
There is only one size for a SBC crank damper bolt. That's why you can go to the store and just buy one from ARP or Moroso or Spectre or whoever, and there's only one part #.
Old Feb 25, 2003 | 03:59 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
well the crank was new andi put it in myself. so i am really confused here.
Old Feb 25, 2003 | 04:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I personally am unwilling to accept responsibility for what may have happened to your crank. I have heard of people drilling them out and using a BBC bolt, which is ½"; but of course, like I said, they didn't come from GM that way.
http://store.summitracing.com/partdetail.asp?part=10064
http://store.summitracing.com/partdetail.asp?part=16909
Old Feb 25, 2003 | 04:08 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
alright thank you. i will buy one on my way home now. i hope it works. i spose its worth a shot since i need one anyway.
Caspar
Jun 19, 2016 11:19 PM
Navy8125
Aug 22, 2015 07:13 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 12, 2015 11:33 AM
