cam and headers...what to choose what to choose
Old Feb 27, 2003 | 09:27 PM
quicklil87lt's Avatar
i have a fairly stock 305. i have an edelbrock performer intake manifold, edelbrock 600 cfm carb, dynomax cat-back with no cat, removed a/c and the air pump is coming out. i want a new cam and some headers. i have around 550 $$$ to spend . i want to keep my gas mileage. i'm only 17 and work at jewel. lol. thanks for any suggestions would be greatly appreciated
Old Feb 27, 2003 | 09:39 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hookers are pretty good
my 305 has hooker headers on it and they work very well i think even tho i bought my car with them on it so i dont realy have a comparasin.
Old Feb 27, 2003 | 10:29 PM
iroc22's Avatar
Flowtech headers.
Comp cams XE250H.
Old Jun 25, 2006 | 11:29 AM
Mustang Crusher's Avatar
Car: 89 Camaro RS
SLP headers are nice, I have a pair of those. I also have a Flowmaster cat-back...with high flow cat. Trust me it sounds sick as hell. Go with the SLP headers. It's well spend money.
Old Jun 25, 2006 | 01:57 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I don't know much about headers, but I sure wouldn't use the above suggested Comp cams XE250H.
That cam has a 110 deg. lsa, it's lift numbers are low 432/444, and it's duration numbers are short 206/212.
Why in the world would anyone want to install that cam?
Old Jun 26, 2006 | 11:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
after headers and a y-pipe, you may have almost spent your $550. Budget $150 for some uncoated hedman 16470's or something, and $100 for the y-pipe. If you're lucky, you can put 'em in yourself, and not have any problems. ok, $300 or so spent. If you are unlucky, and need other exhaust work done at a shop to fit 'em in, then you get to that $550 rather quickly.
The cam with lifters will set you back another $200 or so, throw in some gaskets, timing chain, fluids, and you're out a cool $250-$300 for the cam.
The 250H is far better than the stock cam, but that's not saying a lot. I was thinking the 256, or 262...
Old Jun 26, 2006 | 11:59 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Both the 256 and 262 look like good choices to me.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
