fuel pump
Old Mar 4, 2003 | 05:46 PM
wild 87-Z's Avatar
fuel pump
I have an 87 z-28 with a 305 w/tpi. I went to start the car one day and I noticed the fuel pump didn't come on. I replaced it once already a few years ago and it's a real pain so I wanted to know what else could be wrong before I go pulling out the gas tank again. I haven't put too many miles on the car since I changed the pump last. I checked the fuse and it's still good. Any help would be appreciated. Thanks
Old Mar 5, 2003 | 04:11 PM
84and85bird's Avatar
Car: 84 Firebird & 85 Firebird
Engine: 2.8 V6 : 2.8 V6
Transmission: 700R4 : 700R4
I replaced my fuel pump last fall. I could still hear it kick on even though it was bad. If you're not hearing the fuel pump turn on maybe the problem is electrical.
Have you replaced your fuel filter since you did the fuel pump? I'm almost sure that a clogged fuel filter is what did my pump in.
Old Mar 5, 2003 | 09:37 PM
Vader's Avatar
87-Z,
I'd check the pump relay and fuse.
Old Mar 5, 2003 | 09:50 PM
wild 87-Z's Avatar
Vader, do you know where the pump relay is located? and on a good relay, would the voltage be the same going out as it is going in? I checked the fuse in the fuse box and it is still good, is there another one I need to check?
Old Mar 6, 2003 | 09:54 AM
Vader's Avatar
87-Z,
A Camaro has the ECM/Fuel Pump fuse in a holder near the battery, clipped to the right inner fender:
The fuel pump relay is mounted on the firewall, near the master cylinder and brake booster:
You should get power on the orange wire at the relay at all times. The tan/white wire should get power when the relay is energized.
Old Mar 7, 2003 | 06:29 PM
wild 87-Z's Avatar
well I checked all the fuses and they're all good, changed the fuel pump relay and that didn't work, then I ran power to the g terminal and the only the thing that happened was my maf relay would make a clicking noise so I changed that and it still clicks. is there anything else I can do before I go yanking out the tank? I tried to find wires going to the pump at the back of the car near the tail lights and under the car near the tank, the only thing I saw was a plug going through the bottom of the car in front of the tank going through to the back seats. does anyone know if those are the fuel pump wires?
Old Mar 7, 2003 | 07:39 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
That plug has three wires. one ground, one fuel level sender & one fuel pump power.
Old Mar 7, 2003 | 07:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's a wire trace for you. Ignore the "v6" part... it's the same fuel pump setup as tpi, but tpi uses a higher-flow pump. I typed it up a while ago, even though it's for diagnosing code 54, it'll help you trace all the wires in your fuel pump system. If you replace the pump again, don't re-use the pulsator.. there's tons of messages up here on thirdgen.org about it, just click on search in the upper right hand corner of this screen.
DIAGNOSTIC CHART FOR CODE 54 (2.8L MPFI ENGINE)
---------------------------typed by Tom P------
Preliminary stuff:
Ignition off for ten seconds.
Ignition ON, listen for in-tank fuel pump
Fuel pump should run for 2 seconds after ignition on
Not ok? See "1"
Okay? See "6"
1. Ignition off. Remove the fuel pump relay, but keep the harness connected. This is
____located on the top of firewall, driver's side, on a relay bracket. It's the leftmost
____relay, with a connector that has these wires: Tan/white, black/white, green/white,
____orange, orange.
____With the relay still connected, back-probe terminal "A" (that's tan/white, circuit
____CKT #120) with a test light to ground, make sure you can see the test light from the
____driver's seat. Turn the Ignition to on (don't crank the engine/start the car). The
____light should turn on within 2 seconds.
____Light on? See "1A".
____Light off? See "2".
___1A: Repeat the test on CKT 120 (tan/white) at the rear body connector. You saw this
________connector if you replaced the fuel pump, it's in front of the tank, against the
________top of the underside of the car.
________Light on? Faulty pump ground or pump (ouch!)
________Light off? Fix the open (break) in circuit 120.
2. Disconnect the pump relay. Put the ignition on, engine stopped. Probe the fuel pump
____harness connector, terminal "E" (orange on the edge of the connector, Circuit 340)
____with a test light to ground.
____Light off? See "2A"
____Light on? See "3".
___2A: Repair open in CKT 340, this comes off of both your "computer-and-oil-pressure-
________safety-switch" setup and your "fuel-pump-and-computer-fuse".
________Your fuel pump/ECM fuse is under your hood, screwed down to the upper-frame-rail
________on the passenger side of the car, close to the air cleaner & black fuel-vapor-can.
________You'll see two little black boxes, each with two wires coming out of them, screwed
________down to the upper frame rail by one screw each. One of them has a red wire and an
________ORANGE wire coming out of it- that's your pump/ECM fuse holder. Pop the top off
________to see the fuse. (The holder with red & brown wires is for your 85-89 MAF sensor.)
________Now, two things could happen here. You could have a bad fuel pump fuse- check the
________fuse. If it looks okay, replace it anyway... sometimes a fuse can look good, but
________really be blown. The second possibility- I want you to probe the red wire on the
________fuse holder with a test light to ground. The red wire goes to the positive-
________junction-block on the radiator support- your pump/ECM fuse might not be getting
________any power! If the light doesn't light, check the red wire hookup. However, with
________either case your computer would be acting up, too, and I don't think you could get
________the car to start at all.
3. Connect a test light beteween pump connector pin "B" (black/white wire, CKT450) and
____pin "E" (orange wire from step 2, CKT340).
____Light off? See "3A"
____Light on? See "4"
___3A: Repair open CKT 340. The black/white wire isn't making a good ground. Sorry, I
________don't know where this grounds out to. I'd imagine it goes to a screw on the car.
4. Connect test light between pump connector terminal "C" (dk green/white wire, CKT 465)
____and ground. Ignition to "off" for 10 seconds. Note test light within 2 seconds after
____ignition "on".
____Light on? See "4A"
____Light off? See "5"
___4A: Faulty Relay! Hey that's cool, a $10-$15 part from the GM dealer! But, if you
________replaced that already, something's funny. You might want to do the chart again.
________Check for intermittant connections, possibly caused by dirty connector contacts.
________Note: The manual continues to test the "oil pressure safety switch", I'll put
________that test at the end of this message.
5. Ignition "off". Disconnect ECM A-B connector and check for an open, or a short to
____ground, in circuit 465- that's the dark green/white wire from the relay. It's on
____terminal "A1" of the ECM A-B connector.
____CKT 465 okay? See "5A"
____CKT 465 Bad? See "5B"
___5A: Check resistance across pump relay pins "opposite harness connector terminals B
________and C". Should measure 20 ohms or more to be good.
___________Resistance good? Faulty ECM A-1 connector, or bad ECM
___________Resistance bad? Replace Relay AND ECM.
___5B: Fix CKT 465. If CKT 465 was shorted to ground, re-check for a light "on"
________between harness connector terminal "C" and ground within 2 seconds after ignition
________"on".
___________Get a light? Cool, reconnect your relay
___________No light? Faulty ECM terminal "A1", or bad ECM.
6. Clear codes. Start engine and note service engine soon light. If the light comes
____on, check the code, if it's not 54 or you don't get a light, it's something else
____wrong, or an "intermittant" problem.
7. Backprobe ECM terminal "B2" (that's tan/white, CKT 120) with a test light to ground.
____Ignition off for 10 seconds. Note light within 2 seconds after ignition on.
____Light on? See 7A
____Light off? See 7B
___7A: Faulty ECM terminal "B2" or bad ECM.
___7B: Repair open circuit 120 to ECM terminal "B2".
*** Oil pressure switch test: Our 2.8's have two oil pressure switches. One is for the
gauge panel to control our oil pressure light (or gauge). The other one will keep the fuel
pump running if the relay happens to die while you're driving. I assume the theory was that
if you pull out onto a highway and the relay dies, you don't get killed? Contrary to popular
belief, this switch does NOT turn the pump off if oil pressure goes to zero. That's false,
and can easily be seen by looking at the f-body's wiring diagrams. Anyway...
OP1. Start the engine, get it up to normal operating temperature. If you can, verify that
______the oil pressure is normal. Disconnect fuel pump relay- the motor should keep running.
______Engine stops? Bad oil pressure switch.
______Engine keeps going? See "OP2"
OP2. Reconnect fuel pump relay. Ignition "off". Find the fuel pump test terminal on the
______ALDL (Assembly Line Diagnostic Link, the connector above the driver's feet you used
______to get the error code out), which is terminal "G" -- the bottom leftmost terminal.
______Probe that terminal "G" with a test light to ground.
______Light off? No trouble found! (Doubtful, if you got this far & nothing's wrong...)
______Light on? Bad oil pressure switch. Oh yeah this switch is screwed into your engine
_________________block, right above your oil filter, with an orange and a tan/white wiring
_________________harness on it.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Mar 10, 2003 | 03:56 PM
wild 87-Z's Avatar
on the pictures and diagrams I've seen, there are four relays on the firewall. I have three. my fuel pump relay has four wires, two orange, one black and one blue. the tan/white wire is going to my maf relay. I found out that it's my fuel pump relay that makes the clicking noise. when I hook a test light to the blue wire it makes it click. does anyone know what's going on?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
