Have some ?'s on my cam install, help ok
Old Mar 27, 2003 | 08:31 PM
RICHRAD's Avatar
Finally getting around to installing my comp268. Is the comp#3100 agood timing set and what about these locking plates or cam buttons....Do I need them? I read in a search that this chain set won't rub the block, correct?
Old Mar 27, 2003 | 08:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is an excellent timing set, maybe the best for the money for a street motor or even a fairly wild one. Good choice for that cam.
It has fit every motor I've ever used it in, no problems.
Bolt retainers aren't necessary but are a good idea. I don't generally use them, sometimes but not always. I've never had cam gear bolts back out but I've known other people who have.
A button isn't necessary for a flat tappet cam. It is absolutely essential for a "retrofit" roller cam.
Old Mar 27, 2003 | 08:50 PM
RICHRAD's Avatar
Even a good choice for a 305? (no bore out or stroke). The heads are in the machine shop. Went with 113 vette heads. Plan on gasket matching those to a Weiand action plus.
Old Mar 27, 2003 | 09:23 PM
Vader's Avatar
If they supply a bolt locking plate free with the timing set, use it. If not, don't buy one. To my knowledge, I've never had a cam sprocket come loose from the end of the cam, but I use medium strength Loctite (242).
And you'll want 20 ft/lb on those bolts.
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
