heads
Old Apr 2, 2003 | 09:59 AM
theREIS's Avatar
heads
I have a blown head gasket. I am about to start but before I do I need to know torque specs and torque sequence for the heads and intake. Any other things I need to know? Any info would be appreciated.
Old Apr 2, 2003 | 10:50 AM
gruveb's Avatar
Car: 1989 IROC-1
Not to sound like a smart ***, but go buy a Haynes manual.
It has all of the information you need for this job and then some.
It's much easier to have a manual laid out on the radiator support than to run back and forth to the computer or to try and read your notes.
Old Apr 2, 2003 | 11:05 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
This is off the top of my head..... but I'm 99.9% sure it's right.
It's really pretty easy, just start in the center and rotate clockwise.
Go in 3 step 15lb increments for the heads, and 2 step 15 lb increments for the intake.
I.E. Heads..... 35/50/65
Intake 20/35
Old Apr 2, 2003 | 11:15 AM
gruveb's Avatar
Car: 1989 IROC-1
Intake manifold is 30, at least that's what I thought.
Either way, that's why you should get the book!
Old Apr 3, 2003 | 08:53 AM
theREIS's Avatar
thanks guys, I will have to pick up a haynes. For any of you who have done a head gasket job, how long did it take, approx. hrs/day?
Old Apr 4, 2003 | 09:48 AM
Vader's Avatar
Which vehicle has teh failed head gasket? Repair time will depend on the engine, fuel system, etc. Also, there may be some other things you'll want to check while the heads are off, and some optional work that could be done with the heads removed if you have the time/will/budget.
Old Apr 4, 2003 | 03:51 PM
theREIS's Avatar
its an 87 Z28 with an 89 vette motor
Old Apr 4, 2003 | 04:01 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, if I were you I would use head bolt washers and don't forget to put sealer on the head bolt threads.
Auggie
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
