question bout removing the a/c and air pump on serpintine system
Old Apr 14, 2003 | 11:32 PM
XGMZombie's Avatar
How can this be done. can i get an aftermarket braket or sumthing to do this. i put a 72 350 motor in my 92 camaro rs and it has the serpintine system on it so i have to use that otherwise id be using the vbelts. thanx for any info
Old Apr 14, 2003 | 11:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
get a 1LE a/c delete pulley from online or your local gm dealer and have your a/c system disharged before removal. As for the smog, see the tech article in the tech section for info on removing the smog. The A/C and smog are pretty easy to remove, especially without the motor in, since all you have to do is jsut not reinstall it.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
