Pulling Motor, Need Tips
Old Apr 18, 2003 | 11:22 AM
VegaJsZ28's Avatar
Whats the easiest way to pull the motor? With or without the transmission? Is there any tips you guys can give me? Thanks!
Old Apr 18, 2003 | 12:30 PM
1986redbird's Avatar
I have done it both ways, if you have to take the tranny out for any reason (rebuild,swap,etc,etc) then pull them together, but, if you are leaving the tranny alone then just pull the motor. you will have to support the tranny with a jack or something once you pull the motor or it will fall onto the ground. there are a few bolts over the bellhousing where it bolts to the motor that can be a pain to get to but heres how I did it and it wasn't that bad.
remove distributer from motor.
place jack under tranny.
remove tranny crossmember
lower tail end of tranny to ground
use LONG extensions to reach top bellhousing bolts and remove them.
jack tranny back up.
reinstall tranny crossmember
leave jack under tranny
remove the rest of the bellhousing bolts
after unhooking all the wires and hoses.
hook up engine lift and pull that succer out of there.
there are alot of steps I missed but I was just telling you how I got to the top bellhousing bolts.
Old Apr 18, 2003 | 02:38 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
if you have a manual trans it is only 4 bolts holding the tranny to the bellhousing. Then you can leave the trans in the car without removing the bellhousing from the engine. That is how I did it 3 weeks ago.
Hodge
Old Apr 18, 2003 | 04:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Helped a friend pull a 2.8 from his Camaro, we unbolted the trans first. We unbolted all of the bellhousing bolts from underneath the car. http://www.geocities.com/tomp_3rdgen for pictures!
Old Apr 18, 2003 | 05:02 PM
VegaJsZ28's Avatar
Thanks for the info guys im sure this will help a bunch!
-Jay
Old Oct 30, 2005 | 07:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
how do you actually pull the motor after you unbolt the bellhousing without bending the tranny input shaft??
Old Nov 2, 2005 | 07:37 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
pull the engine forward. The problem you'll run into is that the engine hoist will hit your bumper. move it around to the side to save your paint. I removed mine with the tranny in the car but I was VERY GENTLE. What I found out is that when I put the engine back in, it was easier to drop the tranny, put the engine in, and then hook up the tranny and the driveshaft. The tranny is not that hard to drop so you might do yourself a favor and take it out before removing the engine.
Old Nov 2, 2005 | 07:58 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Am I the only one with small enough hands to unbolt the tranny from above? No extensions needed, I have long slender arms and reached in from above without any problems at all.
Old Nov 2, 2005 | 08:05 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I did most of my bellhousing bolts from up top but had to crawl under for the bottom one on each side.
Mickeyruder
Sep 2, 2015 02:45 PM
neekolzun
Aug 24, 2015 04:59 PM
Hello, Michael
Aug 20, 2015 03:19 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
