gas question
Old Jul 24, 2000 | 06:29 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
gas question
I just read somewhere that my 87 Iroc L98 is made to run on regular 87 Octane gas. I already knew this but this reminded me to ask this question. For the 4 years I owned my car I used 93 octane just because I never wanted to hear it ping if there was a problem. Now with gas costing So much I was thinking about switching to 87 octane. Should I even try 87,89 to save money or continue with 93? My car has 101500 miles mods are below. I only drive it 8000 miles a year so I wont save too much if I switch
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
Hopefully Coming Soon: Emissions legal daily diven 383,afr heads, cam??, Slp 1 3/4 headers, super ram, high flow base, strengthened 700r4. any suggestions please tell!!
Some pics of it at
http://photos.yahoo.com/john5911
Old Jul 24, 2000 | 07:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I run the 87 with my '89 L98, timing set to 8* BTDC, no ping, no knocks detected. I just turned 100K on the motor.
Old Jul 24, 2000 | 08:13 PM
Toxic Avenger's Avatar
For daily driving high octane gas in a stock Camaro engine is a waste of money. You need to run the higher octane stuff in high compression engines only; end of story.
1982 Z28 Pace Car
383 Small Block 4 bolt
Performer RPM manifold, Holley 750 vac sec, Crane cam, 2.02 heads
TH400 trans (TCI Parts)
7.5 10 bolt rear w/3.73 Posi
Shorty headers, True dual exaust
Custom 4 core rad
Autometer tach and guages
Ultra rims w/BFG Drag Radials
13.60 @99 Mph
http://www.82pacecar.homestead.com/files/index.html
Old Jul 24, 2000 | 10:34 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The TPI engines have knock sensors mounted in the block. If you are running 87 octane gas in the car it might run fine or maybe it will only appear to run fine? You might be getting very light detenation that the knock sensor is detecting before you can hear it. The computer will then pull timing out of the engine to stop the detenation. The pulled out timing will stop detenation but it will reduce power and reduce gas milage. A TPI engine has a compression ratio of 9.5 : 1 that ratio usually needs at least 89 octane fuel to stop detenation.
Old Jul 24, 2000 | 11:12 PM
stalemate's Avatar
I was wondering should I run 93 in a corvette Lt1?
Andy
1987 Iroc w/ LT1
350 Turbo trans
2.25 inch Cowl Hood
Adjustable Nitrous Setup(75-175 Hp)
T-tops
mustangman65_79
Sep 1, 2015 03:51 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
