Mark IV big block convert to roller cam
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
Does anyone know what all is needed to switch to a hyd. roller cam in a 1976 (I believe Mark IV) 454?
Roller cam
Roller lifters
Correct gear for distrib. (mine is shot)
Thrust button
Correct length pushrods
Is this an accurate list? Is this all I need?
Roller cam
Roller lifters
Thrust button
Car: 4
Engine: 6
Transmission: 5
Yup, that's about it.
Big blocks are even worse about valve springs than small blocks though; make sure they're up to the task. Stock ones are TFT. Looking at your cam specs, you obviously don't have those at least.
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
454, big, block, cam, cams, camshaft, chevy, conversion, convert, converting, gen, generation, iv, mark, roller
