Code 41? What the heck is it?
Old Apr 24, 2003 | 05:50 PM
Momar's Avatar
This is on a 85 LG4 setup. It is a 350 but I retained the 305 computer carb and dist. I just started driving it and am getting a code 41. I looked it up but am at school right now and dont remember exactly what it said. It said something about checking for a ground at some terminal. I didnt know how to find this terminal. I think it said something about this only being necissary on v8 engines whatever it was. What should I do?
Ben
Old Apr 25, 2003 | 08:22 AM
Vader's Avatar
Momar,
41 EST circuit failure - no distributer pulses
If th eengine runs, you know that you have distributor pulses, but the EST isn't getting them. Check the EST connections and bypass connector to make sure they are intact.
Old Apr 25, 2003 | 04:59 PM
Momar's Avatar
What all connections could cause this? There is the one at the est module right. Then I also will have the ones at the dist. What terminals do I need to check. Thanks for the response.
Ben
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
