What part is this???
Old Apr 30, 2003 | 07:35 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
what is this part that i have circled? It goes with the smog pump. It had 3 hoses connected to it. Im doing the valve covers and a bunch of other stuff to my motor and the plastic hose elbow broke off of it when i removed the hose. where can i find one? This is not my car..just a pic i found. Any help will do. Thanks.
Old Apr 30, 2003 | 07:38 PM
90formula5.7's Avatar
re
that my man is a heater control valve!!!
Old Apr 30, 2003 | 08:47 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
pretty sure that is the air pump switching valve. not sure what a heater control valve looks like, are these two parts similare or is one of us just wrong?
Old Apr 30, 2003 | 11:36 PM
rezinn's Avatar
That is most definitely the heater control valve in the picture. The diverter valve connected to the smog pump may look vaguely similar, except that it's a box and not a little valve with a vacuum fitting on top. It does, however, have a similar looking circular side that the case goes over, I guess.
If you broke a nipple off of the diverter valve.. just glue it back on. I'm pretty sure you did since you didn't say that coolant spilled out, which would have been the case if you broke what you circled in the picture.
Old Apr 30, 2003 | 11:37 PM
TorchRay's Avatar
Car: 89 WS6 Formula
no clue there tekviper. Any info at all will help though. anyone else help out at all...i really got to find out what this is so i can get a new one.
I cant remember is coolant spilled out or not. But i definetly need to get a new one or used one. The nipple that proke off one of the lines the other part of it is still pretty well inside the hose so im going to hald to get another hose as well. Its the nipple on the bottom part of the valve with the short hose 5/8 diameter going to the throttle body.
Old Apr 30, 2003 | 11:39 PM
rezinn's Avatar
This black box in the center is the diverter valve.
edit: Actually, I'm wondering if you broke the nipple off of the top of the heater control valve? If so, just try to glue it back on. You can buy a new one at any auto parts store, it's probably not worth replacing if you could just fix it, though.
Old Apr 30, 2003 | 11:42 PM
TorchRay's Avatar
Car: 89 WS6 Formula
ok that helps out. Yeah the box....nothing broke on that part...just the valve. Looks like a T with 3 nipples coming out for hoses to attach to. One of them broke off. Any idea where i can get a new one? Auto parts store?......or do i have to go to GM?
Old Apr 30, 2003 | 11:43 PM
rezinn's Avatar
Auto parts store, ask for a heater control valve. GM may have it as well.
Old Apr 30, 2003 | 11:44 PM
TorchRay's Avatar
Car: 89 WS6 Formula
ok great. Thanks alot. reall appreaciate the speedy response. Ill let you know how i make out. Thanks again.
Old May 1, 2003 | 01:19 AM
joshp14's Avatar
Go to any auto parts store. I think that EVERYONE should replace it whether it needs it or not because these parts can surely leave you stranded if they fall apart, which I have heard that they do around 100K. It's a no brainer replacement for $15 and significantly reduce the risk of a problem in the future.
Old May 1, 2003 | 01:46 AM
txhotRS's Avatar
speaking of the heater control valve... I'm trying to clean up my engine compartment a little (so you can see all my chrome *bling bling*)... and plus, it annoys me...
what is the best way to re-route the heater hoses that go to the control valve... If I remove the valve and just go with the hoses off to the side, what will happen, will something not work ??
thanks
Old May 1, 2003 | 09:38 AM
TorchRay's Avatar
Car: 89 WS6 Formula
well...thanx for all the info. just came back from advanced today and got a new one. Thanks for all the help everyone...couldnt of done it without ya.
Old May 1, 2003 | 09:26 PM
91 Camaro Z28's Avatar
YES THE LITTLE PLASTIC SONOFA****** WILL FALL APART AT ALMOST PRECISELY 100K miles.. i was removing my TB to clean all the gunk out when i first bought the car(96,800miles)-- well when removing it, i guess i BARELY touched the heater control valve and it basically crumbled in my hand-- well i thought, its just a plastic piece, it doesnt look that important- so i put everything back together and JUST FOR KICKS, cranked the car to see what the black POS was for- well the most amazing GREEN RAINBOW shot about 6 ft across the engine and into the yard- pretty funny sight as i'm sure you all can imagine. it was only like 15 bucks at Autozone and well worth replacing it. Theres a free mod in the tech articles section about bypassing the TB coolant line- thats where it runs from- pretty useful mod too. Your hands wont get burned as much off the TB with it. anyway, hopefully my little anecdote helped lighten ya'lls days.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
