Bogs only during off idle acceleration...
Old May 4, 2003 | 01:04 AM
CamaroX84's Avatar
My new setup is in the sig. The car runs great except for coming off of a stop sign. If I slowly put my foot into the gas, it runs okay. If I give it any kind of quick jab with the gas to get the car moving quickly, it bogs for a second or two (sometimes pops, I'm assuming a backfire in the intake) and then the car suddenly launches. After I get going, the car runs great. No problems under part or full throttle. It is only on the initial launch when this occurs. My idle/drive vacuum is about 6.5", and I just put in a 4.5" power valve. Is this a mismatch? Could my accelerator pump be bad/mismatched? Any help would be grealty appreciated. Thanks
Old May 4, 2003 | 10:17 AM
Vader's Avatar
Sounds like niether one of your double-pumpers is pumping.
Old May 4, 2003 | 11:13 AM
CamaroX84's Avatar
Okay, I think I misworded my problem. It's more of a slight hesitation, not so much a bog. If the pumpers weren't working, wouldn't the car just fall on its face? The car runs awesome at full throttle. Thanks again.
Old May 4, 2003 | 08:16 PM
Vader's Avatar
It sounds lean from your description. Your idle vacuum sounds incredibly low as well. Your cam duration is probably a part of that, but you should be generating more idle vacuum than that. What is the hot idle RPM, anyway?
Old May 4, 2003 | 09:27 PM
CamaroX84's Avatar
The vacuum reading was in drive. In park, it's at about 10". I don't know what could be causing the low vacuum besides the cam. There is abslutely no vacuum leak. Hot idle RPM is about 700. Thanks again.
Old May 5, 2003 | 10:24 PM
CamaroX84's Avatar
I think I just realized why the vacuum was so low...I checked it in drive with my foot on the brake (power brakes). Thanks again.
Old May 5, 2003 | 11:57 PM
ronterry's Avatar
Car: '94 Corvette
Most of the time automatics with double pumpers require a little bit bigger Accelerator Pump Discharge Nozzle. In other words, you need to try bigger squirters...
http://store.summitracing.com/produc...earchtype=ecat
If your running a .028, try a .035 or something till you get rid of the off idle lean. Don't over do it though. If your nozzle are to big, you'll also pick up a bog. Dumping out black smoke will clue you in if there to big.
BTW: There is an accelerator pump tuning kit, which might save you some money in the long run. It comes with nozzles & cams.
Ron
pjsparts
Oct 29, 2025 06:39 PM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
middian
Sep 5, 2015 01:42 AM
