Pushrod Help
Old May 14, 2003 | 10:26 AM
Faster1's Avatar
Pushrod Help
While rebuilding my 350 TPI motor, i plan to replace the pushrods, what kind are good for my new motor with a little more compression? I have the Keith black pistons plus the LT4 hot cam. You need to replace the pushrods when rebuilding a motor, correct?
Old May 14, 2003 | 10:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Generally yes, but they have nothing to do with pistons or compression.
With the bigger cam, you'll probably need slightly longer than stock ones. The only way to know for sure, and get it right, is to use an adjustable push rod, after the motor is together.
http://www.competitioncams.com/catalog/278.html
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
