Flex plate quetion
Old May 26, 2003 | 09:33 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Flex plate quetion
Im assuming I cant use the flexplate off my 327..on my 400sb..internally balanced vs externally balanced..correct...? Also, I'm assuming I need the 168 tooth model, Correct? I will be running my 700r4.(until it breaks) Thanks!
Old May 26, 2003 | 11:07 AM
Vader's Avatar
Correct.
Old May 26, 2003 | 12:31 PM
Engine: 406
Thanks Vader..Im going to take some pics of the rotating assembly, the crank has some strange weld/fill? marks on it...the previouse owner spent quite a few $$$$ on this motor. He claims $7000. It was built by Racing Head Service. Ill post the pics tomorrow evening...Im going to wait on ordering the flexplate til you guys check this out.
Old May 26, 2003 | 12:33 PM
Engine: 406
Racing Head Svc
Address: 3406 Democrat Rd
Memphis, TN 38118
Im told this company and Comp Cams are one in the same. Is this true?
Old May 26, 2003 | 08:50 PM
Engine: 406
Well I went over to the garage today. The balancer on the motor is the 400 type....had the "missing chunk" as RB describes..I will order the above mentioned flywheel.....I will still post pics of the rotating assembly ...the work to the crank has me kinda wondering
codeysabatini
Nov 10, 2015 04:07 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
