Clutch Chatter
Old Sep 11, 2000 | 04:55 PM
Hulk0202's Avatar
Clutch Chatter
I just replaced it and it chatters alot. It stops with any pressure on the pedal. What is it, is it bad, and how can I fix it?
Old Sep 11, 2000 | 07:54 PM
Macgyver's Avatar
Totally just guessing here, but maybe you didn't break in the clutch properly and it hasn't "seated" well enough for smooth operation...
Old Sep 11, 2000 | 08:30 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Did you have the fly wheel resurfaced?
Old Sep 12, 2000 | 07:54 AM
tesla042's Avatar
Same here! Maybe 3 weeks ago I got a new tranny, clutch, and they machined up the flywheel..
Sometimes it chatters upon takeoff.. Sometimes it doesn't.. I assume it's my driving style, but I've been trying to isolate the part of my style that's causing it...and I can't seem to reliably duplicate a non-chattered launch.. bah!
I was REAL NICE on it the first 250 miles, too!
91 T/A 305
STB, Airfoil, Hooker cat-back, pseudo-cold air to K&N, Accel coil, !cat, !smog pump.
300 lb*ft of rice churning power.
Old Sep 12, 2000 | 01:25 PM
Chuck Everly's Avatar
One very common mistake people do when changing a clutch is not replacing the pilot bushing. This allows the transmissions input shaft to bounce around and causes clutch chatter when taking off.
The other obvious think is to make sure the flywheel was resurfaced. I had one clutch that was a little moody and that was because it had a lot of Kevlar in it. That will make the clutch a little grabby and chatter especially when the clutch gets hot.
88 IROC convertible
So slow it is timed with a sundial
Old Sep 12, 2000 | 04:13 PM
Hulk0202's Avatar
I did resurface the flywheel. I can live with the chatter if its not going to cause any problems.
Old Sep 12, 2000 | 06:00 PM
T and A's Avatar
Mine does the Exact same thing as tealas. I didnt repalce the pilot bearing, so next time I have the tranny out i will have to do that. It just goes to show, that if your gonna do somthin, do it right the first time. Guess I ll just have to learn from this one.
Old Sep 12, 2000 | 07:55 PM
XxWOLFxX's Avatar
I had the same problem - i had replaced everything and resurfaced my flywheel I even replaced the hydrolic - I finally fixed it but just grinding some of the meat off the clutch - and now no more annoying chirping
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
