Machining of block
Old May 27, 2003 | 03:05 PM
ccb_v2's Avatar
Machining of block
Connecting rod bearing went, so pulled the TBI 305 out of the 88 camaro to get it cleaned up. I am looking to see what to expect to have the block checked over and cleaned up. There was no scoring on the crank nor on the connecting rod. Just curious what to expect from a machine shop to have the block checked ofer and cleaned up. I don't want anything special done, just checked and cleaned up.
Thx.
Old May 27, 2003 | 07:30 PM
ede's Avatar
ede
clean 40
freeze plugs 15 labor 10
cam bearings 25 labor 30
bore 8 dollars a hole
surface deck 30 dollars
preasure test 30 dollars
i have a cheap shop
Old May 27, 2003 | 08:40 PM
Aron213's Avatar
Car: 88 Iroc
Originally posted by ede
clean 40
i have a cheap shop
We are about the same as ede, exept we charge 15 a hole to bore and hone and 60 to deck blocks, 30 for heads.
Old May 28, 2003 | 10:34 AM
ccb_v2's Avatar
Decking the block, is that kinda like shaving where the heads go on?
Old May 28, 2003 | 11:00 AM
ede's Avatar
ede
yep that's it, if i don't have a block deck i have it surfaced, sort of liek a big belt sander, only removes a few thousandths and leaves a nice clean flat surface.
Old May 28, 2003 | 11:24 AM
ccb_v2's Avatar
I see, thanks. What should I have done though? I mean, the block has 160,000 miles, has never been tore down like this. What work should I be able to do on my own (ex. mounting hte crank, etc) since I tore it down no problems to the block with the cam, thats where I stopped, just haven't had a change to get back to work on it (new house). I don't have alot of $ and cannot afford to bore it out and have to get new pistons or what not. Thanks ALOT for the info.
Old May 28, 2003 | 11:38 AM
Morley's Avatar
clean 40
i have a cheap shop
Can you come pick up my old 305 and clean/bore it? With prices like that it would be worth it to rebuild it and pit it in another car.
Old May 28, 2003 | 11:46 AM
Morley's Avatar
Get the block tanked and throughly cleaned. You may not have a lot of choice on boring the block, depending on how far gone the bores are.
Summit sells a complete kit for 305 rebuild for $269. This includes; pistons (hypereutectic), main and rod bearings, freexe plugs, rings, cam bearings, oil pump, gaskets, etc.
Bearings and pistons/rings are avialable in std and over sizes.
You'd need to have a shop press the wrist pins out of the old pistons and into the new (piston to con rod).
Old May 28, 2003 | 11:49 AM
ccb_v2's Avatar
Only about 7 hrs from me...
Old May 28, 2003 | 11:55 AM
ccb_v2's Avatar
Is that applicable for an '88?
Old May 28, 2003 | 01:10 PM
ede's Avatar
ede
yeah i know i get a great deal on machine work from what i've read other people on here pay. actually i do better than i posted, i do my own freeze plugs, cam bearings, and do my own valves and seats.
Loudnproud86
Jul 14, 2016 12:59 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
86z89iroc
Oct 5, 2015 01:04 PM
anesthes
Sep 18, 2015 12:34 PM
