rich or lean? what's the difference?
Old Sep 13, 2000 | 10:39 PM
crazyjoe's Avatar
I noticed when I let my car sit running in park, after a while you can smell a strong gasoline odor(very strong). You can smell it when I first fire up the car too. Does this mean I'm running rich or lean or neither? Is this causing possible power loss? If so, how would you go about correcting it? Thanx guys.
'91 TA, 305TPI, mild cam, stock heads ported and polished, ported plenum, SLP siamesed runners, edelbrock TES headers, flowmaster 3" cat-back, 3.73 posi, K&N, custom CAI, hypertech stage II chip, march underdrive pulleys,
"305 my A**" -countless mustang owners, after a good spanking.
Old Sep 14, 2000 | 12:27 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you can smell it, most likely unburnt fuel...rich...and since you say it happens after idling for awhile, I'd guess that the O2 sensor is cooling down enough to not keep the ECM in closed loop operation...
If it's been awhile, I'd replace the O2 sensor.
I just read your sig line....are you using a heated O2 sensor? If not, this is probably the problem...the header dissapate the exhaust heat faster, so you may need to use a heated sensor to keep the car in closed loop.
At idle, the exhaust temps are their lowest....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
Jk_Under
Sep 8, 2015 08:13 AM
lakeffect2
Sep 7, 2015 03:52 PM
greenyone
Sep 2, 2015 03:39 PM
