another engine missing question
Old Jun 3, 2003 | 12:02 AM
notaustin83z's Avatar
Car: 87 Trans Am
Engine: 350 Super Ram
Transmission: Level 3 Raptor 700R4
hi,
sorry if this is a repost, my comp froze when i clicked submit last time, and my post didn't show up...anyways, here goes...
My T/A has been misfiring ever since i bought it about a month ago. It starts up fine (first start of the day) but after a couple hours of driving around it starts to sputter throughout the RPM range (sometimes briefly, and sometimes for the rest of the day). It also Idles very rough after it starts missing. The sputtering starts regardless of water temp or fuel tank level (read the fuel pump posts). So far i have tried setting the timing to the factory spec (6b), new cap and rotor, new coil, plugs (+4's) and wires (accel race wires), and a new fuel filter. The injectors all measure up at 16.8 ohms. The MAF sensor is also fine. I have checked for vaccume leaks but can't find any. Im new to this stuff so any help would be greatly appreciated. This car is starting to drive me crazy.. thanks, nick
Car: 87 Trans Am
also thought i should mention that my car dosn't have a cat. converter....so it can't be clogged
Old Jun 3, 2003 | 12:10 AM
25thanniversZ's Avatar
you might try checking your fuel pressure,wireing,O2 sensor,check to see if your burning plug wires to they could be breaking down from heat if there sitting on or to close to the manifolds or headers whichever your running......but im no longer a tpi guy so ive gottin rusty
Old Jun 3, 2003 | 12:18 AM
Car: 87 Trans Am
thanks for the reply
yep i tried checking the wires too but they came out fine...Ill try unplugging the O2 sensor tomorrow, but i think its fine...I have a air/fuel gauge hooked up to it and it looks like its doing what it is supposed to...im not good at this stuff though...so im probably wrong... thanks again for the reply, nick
Old Jun 3, 2003 | 12:22 AM
unplugging the O2 sens aint gonna help.....if youv got alot of miles it might be worth it to go ahead and buy a new one...not gonna do anything but help either way
Old Jun 3, 2003 | 12:40 AM
Car: 87 Trans Am
will give it a try... I hope it works... I got beat by an old jeep cherokee today....kinda hurts to think about it....
Old Jun 3, 2003 | 02:12 AM
ouch...runnin that bad huh
Old Jun 3, 2003 | 06:07 AM
Car: 87 Trans Am
yeah
Old Jun 3, 2003 | 06:45 AM
ctandc's Avatar
If you have access to the HELMS GM service manual , test the pickup coil in the distributor. While you're in the distributor, replace the ignition module if it looks like it's been there awhile. Even if that's not it, now you'll have a spare, and trust me, eventually you'll be glad you have it
Distributor problems tend to have issue only after being driven a bit...they warm up and then fail.
HTH
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
