Need a VSS buffer pic!
Old Sep 17, 2000 | 01:58 PM
B L A D E's Avatar
I need to know the order of the three wires coming out of the yellow box. Pics would be nice... Vader, where are you?!?!
Old Sep 17, 2000 | 04:52 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I'm not Vader but I have wiring for most F-bodies. here's the VSS wiring for non-fuel injected engines.
http://www.geocities.com/millicanga/vss.jpg
John
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
Old Sep 17, 2000 | 06:03 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Check this out, dude....http://www.angelfire.com/mt/psh/speedo.htm
Pete
Pete's Place
Now at HiOutput.com
83 SC...LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, gray interior from an 86 Firebird SE, seats from an 89 Formula, Wheels from an 83 Z28, springs and rear bar from an 84 Z28, WS6 front bar, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, Accel HEI Supercoil and foam air filter, custom air induction through Z28 hood.....best ET is 14.935@94.14
Old Sep 18, 2000 | 02:30 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Hey Pete,
did I ever thank you for helping me with my speedo problem?
If I didn't, thanks a million.
That article made it really simple to fix.
The shop I take my car to, couldn't fix, so, thanks to you I was able to fix it myself.
You guys are a great resource, I'd be totally lost if not for this website and others like it.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
86 Trans Am & Girls
Old Sep 18, 2000 | 05:14 PM
B L A D E's Avatar
Thanks guys, but thats not what I need.... I have a VSS buffer, but someone cut the wires off the board (the ones that go to the optical sensor) I need to know the order so I can wire it back up.
Old Sep 23, 2000 | 01:30 AM
B L A D E's Avatar
BTTT
Old Sep 24, 2000 | 02:38 AM
B L A D E's Avatar
TTT
GTAman
Jul 3, 2024 07:29 PM
Lanz06
Mar 13, 2019 06:07 PM
J.C. Denton
Sep 21, 2015 04:23 PM
Randomtask2
Sep 10, 2015 08:37 AM
gt4373
Sep 9, 2015 10:29 AM
