Need some answers about a factory 350 tpi cam
Old Oct 4, 2000 | 07:19 PM
BrianB's Avatar
Can someone tell me the specs for a 88 350 tpi cam is? And what the minimum and maximum rpm range is? Thanks in advance
Old Oct 4, 2000 | 07:20 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well, the factory says the min and max are gonna be 550, and max being 5000/5500
that motor is fine till 6000 though.. no prob
Steve
Old Oct 5, 2000 | 12:00 AM
John Darragh's Avatar
1988-89 cam part number 10066049 used on l98's and lb9's w/manual trans has the following specs:
.415/.430 lift 207/213 dur 117 lsa
1989 IROC Convertible, 305 TPI/Auto, KB super subs, Koni reds, BMR strut tower brace, Accel air filters, MAF screens removed - just the beginning!
Old Oct 5, 2000 | 12:47 PM
BrianB's Avatar
L98's never came with a manual trans only the 305's
Old Oct 5, 2000 | 01:13 PM
Dan87IROC-Z's Avatar
Yes, John means the LB9 with the manual transmission has the same cam as does the L98 with the auto.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
Vintageracer
Jan 10, 2020 05:33 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
