Compression Ratio???
Old Oct 7, 2000 | 12:27 PM
Jas89TTA's Avatar
I have a 87 Trans Am that I installed a 350 in and want to get a custom chip made up but need to find out the compression on the engine. The heads are cast iron L98 off a 92 Camaro whats the cc's on these heads? Also I used Gm flat top pistons does anyone know what the piston top volume is in cc? I used a felpro gasket set for a 87 TPI so I'm not sure what the thickness on the head gasket is but I belive I can fined it out. Any one have any idea on what it may be? Is there anything else I need to know on how to figure the compression? Any help will be very helpfull. Thanks, Jason
Old Oct 7, 2000 | 12:35 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
What was the gasket number on the head gaskets?
Are the pistons 2 or 4 valve reliefs?
Was your block decked at all?
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
http://members.aol.com/jwnolte/raven.htm
Old Oct 7, 2000 | 12:54 PM
Jas89TTA's Avatar
The pistons have 4 valve reliefs, the block was not decked and I'm not sure what the p/n is one the gasket I'll find that out on monday.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
