Timing issue
Old Jul 16, 2003 | 09:06 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
Timing issue
Ok guys, I keep reading how to unplug the EST wire near the blower motor to set the timing. I can not find this wire. The lable under my hood says to unplug the 4 wire connector. There is a 4 wire connector that runs to the dist behind the drivers side head. This is what I unplugged to set timing. I set it at 0 degrees unplugged. It appears to be about 16 degrees when plugged back in. Does this sound right?
Oops, almost forgot. 85 berlinetta, LG4 with a CC quadrajet.
Old Jul 16, 2003 | 09:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the est bypass wire is for the fuel injected cars ONLY because if you pull the 4 wire connector, the engine dies because the ecm no longer has a reference pulse. Just make sure the engine idle speed is whats specified. The timing will jump when its pluged back in because the computer will agian be giving it advance.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
