Why do i have to floor it to start it?
Old Jul 18, 2003 | 09:21 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
I have a chevy 350 in my 84 Z28 with a edelbrock 600 cfm carb, SOMETIMES i have to floor the car to get it to start. If it was sitting over night i do sometimes, or i can pump it like 3 times and get it to go, but if it shut it off and come back like 1 hour later it starts right up. AND when i start it when flooring it and i let off the gas it acts like it wants to die, and sometimes does. The cars run great once its started, plenty of power and everything.
Old Jul 18, 2003 | 10:24 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I kinda have the same problem as you. Every morning when I start it up I have to pump the gas for a couple seconds before it starts up. It starts up fine after that.
Mike
Old Jul 19, 2003 | 09:29 AM
1986redbird's Avatar
sounds like the choke is closing too far, try proping the choke flap open when it's cold and start it, if it starts any better then that's probably the problem.
by going to WOT at start-up it forces the choke to open a little bit which will let the engine breath.
Old Jul 19, 2003 | 11:44 AM
Morley's Avatar
You fuel bowl is probably empty after sitting over night.
Old Jul 19, 2003 | 12:30 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Sounds like a problem with your choke. I dont even have to pump my gas to get my car to start. No matter how cold it is outside. During the winter I could jump in and crank it over and it would start.
Maybe you could use alittle more tuning?
Old Jul 19, 2003 | 04:52 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
It's to open your choke. My Camaro, you have to pump it a few times, till she fires. Give it a few revs to about 3500 if it stalls, get some gas a flowin, shes probably fine
Orr89RocZ
Apr 25, 2016 08:28 AM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
