Need advice on Fuel pump install...
Old Jul 19, 2003 | 03:46 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I just blew my Mallory 3 port regulator that I had been using with my stock fuel pump to keep the pressure down for my carb. I've been told I'm going to keep blowing these becouse they are not made to handle the pressure the factory pump puts out.
So I'm going to go with a Holley Blue fuel pump and regulator. My questions are can I leave the stock pump in there? And if so do I have to power the stock pump? I've read so many posts saying with mixed responces that I don't know what to think.
Thanks for your time,
Matt
Old Jul 19, 2003 | 04:29 PM
ede's Avatar
ede
you ought to be able to leave the factory in tank pump in place and not power it. i'd used mechanical pumps and pulled thru the in tank pump with no problems.
Old Jul 19, 2003 | 05:24 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Thanks ede! I just remembered that I have a perfectly good mechanical pump in the garage. I'll try that out.
Thanks again,
Matt
Glowsock
Jul 24, 2025 03:15 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
