Rear engine seal leak?
89 gta trans with a 350
Thick yellow type liquid secreting from rear near exhaust rear engine seal leak? Diff fluid?
How much $$ am i looking at here how hardcore is this?
I know i've got a power steering leak is it possibe it's beading on something and running top the back? Pungent smell also
Please advise....
Please advise....
Pungent? Like sulpher? If so- it's your rear housing that's leaking- probably looks yellow because it's mixing with water (any oil lubricant will get 'milky' looking when mixed with water).
If this is at engine compartment and it smells strong, you're left with 3 choices: power steering fluid, auto transmission fluid and brake fluid.
[This message has been edited by Eric2ndGen (edited October 24, 2000).]
[B]Pungent? Like sulpher? If so- it's your rear housing that's leaking- probably looks yellow because it's mixing with water (any oil lubricant will get 'milky' looking when mixed with water).
Not like sulpher i cant explain it... It's pretty thick aswell and its at the rear like i said is diff fluid a possibility?
Also is it possible to have a connection with inanimate objects? I dreampt my car wouldnt start up last night and today this happens (it did start up tho) I think my car loves me ( i sleep above the garage) i think it's sending me messages whilst i sleep
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
Are you sure it doesnt smell like an egg fart. That is the tell tale diff smell
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
1992 Trans Am
May 10, 2023 07:19 PM
