Lift vs. Emissions.
Old Aug 14, 2003 | 07:16 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Lift vs. Emissions.
Simply put, would going to 1.6 rockers increase emissions?
Old Aug 15, 2003 | 12:23 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The question should be "will more duration increase emittions?"
Lift has very little impact on emittions compared to duration.
I think the 1.6 rockers will probably make it a little worse for emittions, but probably not enough to worry about unless you are already on the ragged edge of passing.
Old Aug 15, 2003 | 08:08 AM
Willie's Avatar
I appreciate the response Adam. I know that duration is a factor in emissions.
Here's the reason why I asked about lift. I'm in the process of firing up a rebuilt engine with a custom designed cam. Because it's a custom job, it is not certified emissions legal. The first place I have to drive to when my car is running again is the smog check station. I can run either 1.5 or 1.6 rockers as I have both sets. I know I'll be close to not passing, so should I stay "conservative" with 1.5's (initially) and take the time to change to 1.6's later or should I not worry about it and go with 1.6's now?
Willie
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
racereese
Oct 10, 2015 09:39 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
