Any Merit to This Lifter Conversion?
Old Aug 19, 2003 | 01:35 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Anyone tried this hydraulic roller lifter conversion? It would appear that the cam tunnel would be too stressed. Maybe the use of helicoil would ease this stress. What do ya think?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33614
Old Aug 19, 2003 | 03:28 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I wouldn't do it. It's not really worth it. Roller cams aren't THAT much better than flat tappet cams.
Sure they have their advantages, but to go through all that trouble... I don't know. I guess it's all a matter of perspective.
Put it this way..... If you're going to rebuild an engine, and spend the money on the machine work, all you have to do is spend another ~$100 for a newer block that's designed for that setup.
Then you get a 1 pc rear main seal as well.
So am I saying it wouldn't work? No. I obviously does.
Is it worth the time, money, and trouble? Not IMHO.
Old Aug 19, 2003 | 03:42 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I don't know why it wouldn't work. All your trying to do is hold the roller lifters straight. I'd like to hear from someone who has done this also.
Old Aug 20, 2003 | 12:27 AM
AJ_92RS's Avatar
Originally posted by 94-6spd
I said.....
...I don't know. I guess it's all a matter of perspective.
It depends on if YOU (the person doing the work and dealing with the results) feel it's worth it.
I don't have to smell a pile of dog poo to tell you it stinks. But I suppose you could walk over and sniff it if you're that worried about it.
Or maybe someone that has already sniffed it can tell you.
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
